1. Kathi Jo Brunning's Avatar
    My Droid Turbo just went blank and was completely unresponsive. Now there is a screen I've never seen before. At the top there's a box with a right pointing arrow on it and the word START. Under that is a Droid on his back and the cover of his abdomen is open. Under that there is a script that reads:
    (In red) AP Fastboot Flash Mode (Secure)
    (In white) BI or BL: noto-apq8084-70.8A (sha-021bfc8, 2016-04-05 12:03:09)
    Baseband:
    Product/Variant: quark XT1254 32GG P4A
    Serial Number: (I'm leaving this out)
    CPU: APQ8084 ES1.1
    eMMC: 32GB Samsung RV=07 PV=0B TY=57
    DRAM 3072 MB Hynix S8 SDRAM DIE=6Gb
    Console[NULL] null
    (In green) Battery OK (Charging)
    (In white) Device is LOCKED. Status code: 0
    Software status: Official
    Connect USB Data Cable
    What the heck does this mean? What should I do? Thanks.
    07-12-2016 05:54 PM
  2. berserker's Avatar
    I think you can use your volume keys to scroll through the options and the power button to select. Select Restart or Reboot if it's available.
    07-12-2016 09:40 PM
  3. Einsteindks's Avatar
    Fastboot mode, harmless. Kinda like a pc's BIOS. I'd toggle/select recovery and at least wipe cache. The phone 'rebuilds' itself, so to speak, (ART runtime) afterwards. Reboot may take a while.
    07-13-2016 01:22 AM
  1. Replies: 1
    Last Post: 07-14-2016, 03:58 AM
  2. S6 Active, Screen went black flashes blue in left bottom corner. Any help?
    By Danielbuch88 in forum Samsung Galaxy S6 active
    Last Post: 07-13-2016, 03:36 PM
  3. Stuck in download mode/samsung screen, plz help s6 edge+
    By Jacobpdx in forum Samsung Galaxy S6 edge+
    Last Post: 07-12-2016, 06:20 PM
  4. Stuck in download mode/samsung screen, plz help s6 edge+
    By Jacobpdx in forum Ask a Question
    Last Post: 07-12-2016, 04:22 PM
  5. How do I get my Android phone (Cubot X12) out of Safe Mode?
    Last Post: 07-12-2016, 02:50 PM
