So I was trying to do a cache partition clear since I try to do it every few weeks. Well after a couple of minutes it just stopped clearing and all I get is a flickering Android character laying down and says "No Command" like when you go to clear it holding power and volume up.
I then tried powering off/rebooting and it shows the Motorola start screen but then goes right back to the flickering Android character laying down and won't actually turn on. I have tried "Powering off" after holding down the power and volume down buttons but when I try to turn my phone back on I just run into the same issue.
Anyone got any ideas or experience with this here? I need to get this fixed ASAP.
