1. sparko24's Avatar
    So I was trying to do a cache partition clear since I try to do it every few weeks. Well after a couple of minutes it just stopped clearing and all I get is a flickering Android character laying down and says "No Command" like when you go to clear it holding power and volume up.
    I then tried powering off/rebooting and it shows the Motorola start screen but then goes right back to the flickering Android character laying down and won't actually turn on. I have tried "Powering off" after holding down the power and volume down buttons but when I try to turn my phone back on I just run into the same issue.
    Anyone got any ideas or experience with this here? I need to get this fixed ASAP.
    07-15-2016 02:17 PM
  2. Jheebs's Avatar
    At no command screen, hold down power button and press and release volume up button at the same time... Menu screen will come up. Scroll to restart with volume buttons and press power button.
    07-15-2016 03:38 PM
  3. sparko24's Avatar
    That doesn't work either. The no command screen only flickers on every few seconds and I am unable to get to the Menu screen.
    07-15-2016 03:52 PM
  4. sparko24's Avatar
    Well the battery finally died on the phone and I was hoping that would resolve the issue. But when I went to plug it in, it just flickers the "No Command" screen every once in a while and won't actually turn on still.
    No idea what to do here other than bring it to Verizon and hope they replace it since I have insurance.
    07-15-2016 08:30 PM
  5. 1Coopgt's Avatar
    When that's happened to my phone I just hold down the power button. Then it reboots.May take a min. you'll feel the phone vibrate as it reboots.
    07-17-2016 09:40 AM
  1. WTB: Unlocked phone for Cricket Wireless, Need to buy one
    By delta7 in forum The Marketplace - Buy, Sell & Trade
    Last Post: 08-11-2016, 10:25 AM
  2. Replies: 4
    Last Post: 07-17-2016, 07:42 PM
  3. how set 3 display keyboard on LG G3
    By alexa1970 in forum LG G3
    Last Post: 07-17-2016, 01:44 AM
  4. can i put marshmello on a phone that has jellybean on it now
    Last Post: 07-15-2016, 03:32 PM
  5. Motorola Xoom will not power on no matter what i do, help?
    By AC Question in forum Motorola Xoom
    Last Post: 07-15-2016, 01:15 PM
