1. FloatingSpots01's Avatar
    My Turbo comes off the charger and immediately drops 10%. It also shuts down hard at 13% remaining.
    I have fully cycled it down to a hard power off to 100% charged multiple times with any interruption.
    Is there any way to train the meter to be correct? I do not have root.
    09-28-2016 02:03 PM
  2. Laura Knotek's Avatar
    Welcome to Android Central.
    Is this the original Turbo? Are you the original owner, or is it a used phone?
    If it's the original Turbo, it's a rather old device. If it has the original battery, then the battery could be on its way out
    09-28-2016 03:20 PM
  3. FloatingSpots01's Avatar
    It is the original turbo and the battery definitely has degraded. I thought that there would be a way to retain the battery meter, though.
    09-29-2016 06:57 AM
  4. tgp's Avatar
    As Laura said, the battery is probably on its way out. From what I understand the battery level is measured by the voltage. I'm not a battery engineer, but probably it does not hold peak voltage anymore, hence the immediate drop in reported battery level.
    doogald and Laura Knotek like this.
    09-29-2016 07:42 AM
  1. WIFI using battery when turned off?
    By JCHAOS in forum Nexus 6P
    Last Post: 10-01-2016, 02:03 AM
  2. Replies: 18
    Last Post: 09-30-2016, 07:31 PM
  3. What is the best external battery for a TAB A 10.1
    Last Post: 09-28-2016, 01:43 PM
  4. Why when my phone's battery low it drains very quickly?
    By The Strange Tester in forum Ask a Question
    Last Post: 09-28-2016, 01:08 PM
  5. Is your LG G3 battery draining quicker???
    Last Post: 09-28-2016, 11:55 AM
