01-26-2017 04:58 PM
145 12345 ...
tools
  1. hannsoft's Avatar
    So glad I was part of the original soak. Marshmallow been running like a champ for the last three weeks.
    Something tells me the 'bricks' were from overzealous millennials not reading the instructions for conducting the soak test. It clearly stated to ensure your phone was not encrypted.
    Patience can be a virtue
    Actually, no. It did not state that you can't be encrypted. It asked you if you were or weren't.
    12-14-2016 06:27 PM
  2. Angus Repper's Avatar
    That's not what I remember. Sounds like someone didn't follow directions and looking to find someone else to pin the blame on.
    12-14-2016 06:36 PM
  3. krazyatom's Avatar
    12-14-2016 06:58 PM
  4. Jheebs's Avatar
    Went off without a hitch... So far, very smooth... Butter. Put new life into an oldie but a goodie...
    krazyatom and soc_phish like this.
    12-14-2016 08:04 PM
  5. hannsoft's Avatar
    You remember incorrectly, or you weren't a part of the soak. Sounds like somebody trying to make users look like they're at fault for a tech glitch created by a phone manufacturer.
    12-14-2016 09:07 PM
  6. Angus Repper's Avatar
    Just curious...are you a millennial? I am betting yes.
    12-14-2016 10:38 PM
  7. hannsoft's Avatar
    No, but I sired two. Best not to lay any more bets tonight.. you're 0 for 2.
    12-14-2016 11:24 PM
  8. Ry's Avatar
    There's no evidence "millennials" did anything wrong.
    Please knock it off. This type of stuff isn't needed.
    12-14-2016 11:39 PM
  9. soc_phish's Avatar
    I just received my update alert
    VZWsucks likes this.
    12-15-2016 09:20 AM
  10. soc_phish's Avatar
    Wish me luck...😉
    12-15-2016 09:21 AM
  11. jobjohnny's Avatar
    Wish me luck...
    Good luck!
    soc_phish likes this.
    12-15-2016 09:26 AM
  12. GESWhoseBack's Avatar
    Got my update over OTA at 6:30 yesterday evening before work. Worked fine all night. Didn't notice any battery drain, if anything it may have improved it a little. At least for the night.
    soc_phish and VZWsucks like this.
    12-15-2016 10:00 AM
  13. krazyatom's Avatar
    So far so good.
    12-15-2016 11:05 AM
  14. soc_phish's Avatar
    Update Complete. No issues so far.
    12-15-2016 12:18 PM
  15. liseb17's Avatar
    How long did it take for the update to download? My phone's been stuck at 3% downloaded for about 20 minutes now . . .think I should reboot the phone and try again?
    12-15-2016 12:23 PM
  16. krazyatom's Avatar
    I downloaded last night through wifi and it took like 10 mins. I only have 50mb internet service.
    12-15-2016 01:04 PM
  17. Mungus8888's Avatar
    Downloading now...
    Look at that. Marshmallow..
    12-15-2016 02:52 PM
  18. Davidoo's Avatar
    I got my new Google Pixel Tuesday, but turned my now backup Turbo on Wi-Fi and it immediately took the update and all works well. I really loved the Turbo the entire time I had it except for the slow updates.
    12-15-2016 03:33 PM
  19. Mungus8888's Avatar
    Crashed pretty hard after the MM update. After updating a few things. Seems good to go. It's for sale now. Mint condition, armorsuit and Seidio protected since day one. Pixel time
    12-15-2016 04:08 PM
  20. soc_phish's Avatar
    The complete download of the update took about an hour. The complete install and reboot took approx. 25-30 minutes.
    Note: I wasn't comfortable leaving it as is. I factory reset the phone after the update and loaded all the apps manually. Just FYI for others here also.
    12-16-2016 08:52 AM
  21. Cajun_Mike's Avatar
    Downloading now... Fingers crossed that my phone doesn't brick on a Friday afternoon
    12-16-2016 12:23 PM
  22. Cajun_Mike's Avatar
    All good. I really don't notice much difference other than Motorola clock is different and icons look a bit bigger...
    12-16-2016 02:34 PM
  23. 1901Madison's Avatar
    Agreed.
    12-16-2016 03:53 PM
  24. soc_phish's Avatar
    So far it is definitely the same except for some features. I can confirm that the Command Center still Kills my battery...*removed*
    12-16-2016 04:11 PM
  25. ryanidcomm's Avatar
    Update went smooth for me!
    google now on tap is great! I dont like how I cant get to my google now feed as quickly ..
    Phone is still very smooth! Ill update on battery life in a few days
    I did not FDR but I might some time soon. for fun
    12-16-2016 10:27 PM
145 12345 ...
  1. anyone using Android Auto without physical connection
    By lgGslateuser in forum Moto Z Play & Z Play Droid Edition
    Last Post: 12-14-2016, 06:16 PM
  2. android auto stopped working in 2015 sonata after v2 upgrade
    Last Post: 12-05-2016, 01:30 PM
  3. Android System Killing Battery
    By JimK#CB in forum Moto Z & Moto Z Droid Edition
    Last Post: 12-05-2016, 01:14 PM
  4. Windows Phone -> Android : MS Groove vs Google Play Music
    By tribexx in forum General Help and How To
    Last Post: 12-05-2016, 10:05 AM
  5. Android Central app - can't reply in forums
    By popartist in forum Android Central Apps
    Last Post: 12-05-2016, 10:04 AM
