Mungus8888
For what it's worth, I spoke to VZW cs. They had info that MM has been pushed back to early January.
<bitterness> Jan of which year? </bitterness>
Ha! Though, that said, I always say - better later and right than earlier and buggy. (Especially after waiting 6 months for an update to a buggy update.)
Actually, no. It did not state that you can't be encrypted. It asked you if you were or weren't.So glad I was part of the original soak. Marshmallow been running like a champ for the last three weeks.
Something tells me the 'bricks' were from overzealous millennials not reading the instructions for conducting the soak test. It clearly stated to ensure your phone was not encrypted.
Patience can be a virtue
You remember incorrectly, or you weren't a part of the soak. Sounds like somebody trying to make users look like they're at fault for a tech glitch created by a phone manufacturer.That's not what I remember. Sounds like someone didn't follow directions and looking to find someone else to pin the blame on.
No, but I sired two. Best not to lay any more bets tonight.. you're 0 for 2.Just curious...are you a millennial? I am betting yes.
Wish me luck...I just received my update alert //uploads.tapatalk-cdn.com/20161215/3be73afd9cb5487ab9064cbce2370e57.jpg
