1. A55H0l3's Avatar
    Anyone else had an issue with charging their battery without the OEM charger? Once my phone completely runs out of juice; the only way to charge it is connect the device to Verizon OEM fast charger. The device won't let me use any other charger, but the OEM.
    12-13-2016 02:17 PM
  2. PowrDroid's Avatar
    What kind of an a55h013 would run their battery completely dead? Don't do that. Problem solved.
    12-13-2016 03:02 PM
  3. A55H0l3's Avatar
    Didn't really answer the question, but thanks for trying..
    12-19-2016 07:31 AM
  4. doogald's Avatar
    I think he did. Apparently the Turbo won't charge a dead battery without the stock charger, so don't let it get that discharged if you don't want to use the stock charger.
    Motorola's official support for battery charging: https://motorola-global-portal.custh...p/30,6720,9277
    Use the Motorola charger that came with the device. Device chargers can vary in energy outputs and a weak charger will take longer to charge the battery. If a device is in heavy use while charging, a weak charger can't provide enough energy to actually charge the battery at all.
    Charge the device each night.
    The device will give a warning when the battery is low, first when the charge remaining falls below 15% of its capacity, and again when it falls below 5%. When these warnings appear, charge the device as soon as you can and/or stop using applications that can wait for a later time. For example, switch to airplane mode to stop all radio transmissions or stop apps that use a lot of energy (such as navigation or streaming apps).
    12-19-2016 10:49 AM
  5. ryanidcomm's Avatar
    have you tried charging for a long time like an hour or so? it seems to work fine with my 2amp charger.
    12-25-2016 07:08 PM
