1. QED2004's Avatar
    So Verizon sent me an update and my phone went into a boot loop and now it is soft bricked. I didn't even know what those terms were until 3 days ago. I can get it to go to the system recovery screen although nothing solves it, even a factory reset just reboots into the same boot loop. I can get it to fastboot (bootloader, not sure of the right terminology) same problem, the only thing that works is power off. My computer recognizes the phone when it is in this mode.
    I went to a computer repair store, they knew less than I did and couldn't fix it. Verizon wants me to send back my perfectly good phone for a "reconditioned" phone, and the insurance plan won't touch it because the phone technically "isn't broken".
    My question: Is there any way to reinstall the stock OS from an SD card?
    And one caveat before you start ripping me up for not knowing the basics...I am trying to solve this on my own, learning a lot and I am a grandmother. So please be nice and just point me in the right direction.
    01-07-2017 07:00 PM
  2. Einsteindks's Avatar
    Download RSDlite & firmware FXZ, phone into fastboot, plug into computer, open RSD, select firmware, opt decompress & install FXZ
    01-07-2017 07:11 PM
  3. doogald's Avatar
    Before RSDLite, I'd try the Verizon Software Repair Assistant first. See https://forums.androidcentral.com/e?...token=fbwlXlMd
    No requirement to find and download firmware. Use a USB 2 port if you have one. (It doesn always recognize the Turbo if you connect to a USB 3 port. If that happens on your computer, try switching the cable to a different USB port on the computer.)
    B. Diddy and maxman1 like this.
    01-07-2017 07:15 PM
  4. QED2004's Avatar
    doogald anytime you want homemade chocolate chip cookies, you just PM me an address. I fixed my phone!!!! Thank you so much!!!!!!
    01-07-2017 08:11 PM
  5. doogald's Avatar
    Very tempting! And you're welcome!
    01-07-2017 10:00 PM
  1. Replies: 0
    Last Post: 01-07-2017, 03:00 PM
  2. Replies: 0
    Last Post: 01-07-2017, 01:09 PM
  3. No way to disable quick/fast/turbo charging?
    Last Post: 01-06-2017, 03:14 PM
  4. How to set the sleep mode on Motorola Turbo
    Last Post: 01-06-2017, 04:32 AM
  5. Replies: 0
    Last Post: 01-06-2017, 12:52 AM
