1. Ryan Waldbauer's Avatar
    I just downloaded and installed the Marshmallow update and as soon as my phone installed and reset I immediately started having problems with my wifi connectivity. Sometimes it will stay connected and other times it will dump the wifi and give me the wifi disconnected message. I am on the exact same routers with the exact same proximity that I had prior to the update and I had zero issues with them then. This is on every router I have gotten on. I have a Motorola Droid Turbo I purchased in the beginning of 2015. Has anyone else had any issues with this? Any info would be fantastic.
    01-15-2017 09:01 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved from the Marshmallow forum to the Turbo forum, since this is much more likely to be a device-specific issue.
    I know you mentioned this happening on more than one router, but can you see if the problem persists after rebooting at least one of them (by unplugging its power for 10 seconds, then plugging back in)?
    01-16-2017 11:07 PM
  3. rxgadget's Avatar
    Just mentioned this on another post.. I continue to have Wifi issues by getting disconnected on a regular basis at home, other
    Secure places and even free WiFi like Starbucks) which I try to avoid free WiFi)
    01-20-2017 09:23 PM
  4. Tbosephus's Avatar
    I am having the exact same problem. Whether I'm on home wifi, gym wifi, or work wifi, it dumps the connection seemingly at random. I have no solution, just want you to know you're not alone, and it's not your router. I was also having problems with certain apps failing, saying I didn't own them and crashing.
    02-27-2017 07:14 PM
  5. ryanidcomm's Avatar
    i am also having this issue.. ive trouble shot it a lot and determined its definitely my turbo..
    02-28-2017 12:15 PM
  1. Fingerprint and Password Issue
    By pauldroidr2d2 in forum Google Pixel & Pixel XL
    Last Post: 03-19-2017, 07:40 PM
  2. cannot delete trojan on android tablet
    Last Post: 03-08-2017, 01:55 PM
  3. Is this Verizon Samsung Galaxy S4 System Update Real?
    Last Post: 01-14-2017, 10:24 PM
  4. Galaxy S4 software update sdm 1.0
    Last Post: 01-14-2017, 07:31 PM
  5. When will be the last Update Google will do to the Lg g4?
    Last Post: 01-14-2017, 03:19 AM
