1. Ned Squiggly's Avatar
    I haven't been in a hurry to upgrade to a new phone. This phone has been the best and the battery has been a beast.
    But the last few days the battery has been draining fast. I check the battery stats and it's not any app, it's cell standby. When everything else is using 3-4% battery, cell standby is using 30%.
    Anyone know what might be causing this? I don't understand how cell standby could be using way more battery than apps, or even the screen.
    VZWsucks likes this.
    08-23-2017 11:32 PM
  2. Einsteindks's Avatar
    Could be location, app advert download,...
    08-24-2017 06:04 AM
  3. PowrDroid's Avatar
    Can't answer your question about why cell standby is draining your battery but I had the rapidly draining battery problem and found a fix.
    Performed a "wipe cache partition" and my battery is back to normal.
    Instructions:
    https://mobilesupport.lenovo.com/us/...ution/MS102367
    08-24-2017 08:25 AM
  4. doogald's Avatar
    One reason that cell standby will use a lot of battery if you have a poor mobile signal.
    08-24-2017 04:31 PM
  1. WTS: LG v10. Charger and battery white
    By westiewanderer in forum The Marketplace - Buy, Sell & Trade
    Last Post: 03-09-2018, 07:53 AM
  2. Battery Life Plummeting
    By can3gxw in forum Google Pixel & Pixel XL
    Last Post: 08-25-2017, 10:32 AM
  3. Bad battery or just a better charger?
    By dougdraws in forum Samsung Galaxy Note 5
    Last Post: 08-23-2017, 03:15 PM
  4. Why is my android tablet drain so fast
    Last Post: 08-23-2017, 12:20 PM
