1. Moondoggy's Avatar
    I'm not sure if this is a question or a comment as I'm just seeking more information. Has anyone heard or experienced a phone charging/battery drain issue with Flashlight apps from Google Play running on their phones?
    I have a Verizon Droid Turbo and over the last month or so I've been having issues with charging the phone that sometimes results in a complete drain on the battery. What I was seeing is that I could sometimes plug the turbo charger into the phone and you would get an indicator that said that the phone recognized the turbo charger but when I went to use the phone after the charge the phone would be dead. Sometimes it would look like it was charging but then it would stop charging and again the battery would drain. I assumed that it might be a defective charger but after buying one from Verizon it didn't seem to make a difference. The only thing that did seem t work was to power off the phone and then plug in the charger and although it was frustrating it worked.
    Yesterday, however when I was speaking to a 2nd level Verizon support rep on a 4G LTE reception issue I mentioned the charging issue and the rep asked me if I had any flashlight apps installed and I stated that I had the Super-Bright LED Flashlight by Surpax installed. She then asked me to uninstall that app as it was most likely the problem. The rep then asked me to plug in my turbo charger and my phone which was a 36% charged immediately started a fast charge. I've messed with this a few times now and each time I plug in my phone things are working normally again.
    Has anyone heard or experienced a similar issue with their Android phone? Do you know the cause of this problem as I've had this same flashlight app on all of my smart phones.
    Thanks,
    09-04-2017 09:52 PM
  2. mhinc's Avatar
    Thanks,
    I just removed a Flashlight app from my friends phone that was not only eating battery but also using massive data! yes DATA. So I uninstalled it.
    VZWsucks likes this.
    09-04-2017 11:26 PM
  3. doogald's Avatar
    Yes, flashlight apps in the past have been notorious for spying on people, using battery, etc.
    maxman1 likes this.
    09-05-2017 07:23 AM
  4. adamgilcrist's Avatar
    Yes, definitely if you use flashlight app in your mobile, then your battery will drain faster than normal, sometime it create battery issues.
    12-01-2017 07:34 AM
  1. Fossil Q Marshal Update Issue
    By Old Fossil in forum Fossil Q Series
    Last Post: 09-12-2017, 06:49 PM
  2. Video display problem with Galaxy S7
    By KikiHalbert in forum Samsung Galaxy S7
    Last Post: 09-05-2017, 11:49 AM
  3. Replies: 1
    Last Post: 09-05-2017, 11:45 AM
  4. Screen on with music??
    By jcochran1977 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-04-2017, 09:51 PM
  5. Considering Note 8 after 10 years with Apple
    By onmytenthlife in forum Samsung Galaxy Note 8
    Last Post: 09-04-2017, 07:02 PM
