1. davidhill90034's Avatar
    On October 4th, I noticed my device a Droid Turbo began restarting often, taking a long time to boot up. Prior to this my device had worked flawlessly for a long time. I decided to perform a Factory Data Reset via the settings menu.
    Now my device boots up fast however the power button is failing to function in several capacities (see list below). Some apps and the device in general glitch; some functions do not work or no longer respond as they should. This lead me to believe these issues may be fixable by reinstalling the original Firmware. The challenge is to do so without completely bricking my device. I have done some research. The articles I found are often hard to follow, not precise, or simply may not speak to the exact issue(s) my device is experiencing.
    Power Button fails to function in several capacities:
    a) Device won’t Power off. If persistent, device eventually restarts.
    b) Device unable to select Recovery mode via Bootloader/Fastboot mode. I can arrow to the Recovery Menu option with the up or down key, but then selecting it using the power button does nothing and the device restarts.
    Note: Steps a) and b) above are the necessary steps to perform a Factory Data Reset via the Bootloader/Fastboot mode. I successfully used this method twice in the past without issue.
    c) Device no longer sleeps or wakes via power button single click. Device may eventually restart but often does nothing.
    d) Device unable to take screen shots (selecting power + volume down buttons simultaneously). It works once only after device restarts.
    10-07-2017 03:47 PM
  2. Einsteindks's Avatar
    May have to want to reflash with RSD Lite. It won't relock the bootloader, but we'll install everything stock ROM and Recovery
    10-07-2017 09:32 PM
  3. Ry's Avatar
    Might be easier to use the Verizon upgrade assistant instead of RSD Lite.
    canawler likes this.
    10-07-2017 10:48 PM
  4. davidhill90034's Avatar
    I have updated the information above to more accurately reflect the issues my Droid Turbo is having. I would appreciate your feedback. David
    10-19-2017 08:59 PM
  1. Replies: 15
    Last Post: 10-12-2017, 07:30 AM
  2. No Option to switch off mobile data -Tmobile unlocked
    By krishnansasikumar in forum Samsung Galaxy Note 8
    Last Post: 10-08-2017, 02:11 PM
  3. I can't answer my phone by swiping can I change the setting a
    Last Post: 10-07-2017, 07:02 PM
  4. Replies: 1
    Last Post: 10-07-2017, 03:22 PM
  5. All Widgets disappear from HomeScreen and menu list after restart.
    By experimancer in forum Android 7.0 Nougat
    Last Post: 10-07-2017, 03:14 PM
