    How long can that take? well it just finished as i was typing out this question and it took about 5 minutes.... is that normal?... and how often should i do this?
    01-07-2018 06:21 PM
  2. belodion's Avatar
    Cache Partition wipes can take 5min or more on the Nexus 5.
    I’ve never known it take longer than a few seconds on any Android device to clear the app cache, whether one, or all at once.
    Some say it’s good to clear the app cache weekly, and the system cache monthly; others say no need unless problems arise.
    I’ll move the thread for comments from the Droid Turbo guys.
    01-07-2018 07:23 PM
  3. jasonandrews25788's Avatar
    cache partition isn't that fast on moto droid devices
    belodion likes this.
    01-07-2018 07:52 PM
  4. doogald's Avatar
    I know that under KitKat and Lollipop it would take 10-20 minutes to a wipe of the cache partition from recovery. I thought that was "fixed" under Marshmallow to be done faster, but I may be thinking of the Turbo 2?
    Unless you have problems that seem to be fixed with a wipe of the cache partition, I'd say that once a month is a reasonable interval, and, if you miss a month, it won't be that big a deal.
    01-08-2018 12:58 PM
  1. Note 8 light on the edges
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 04-08-2018, 08:53 PM
  2. How do you get rid of certain speed dial numbers in contacts
    Last Post: 01-07-2018, 11:35 PM
  3. How do I turn off the offline English download
    Last Post: 01-07-2018, 11:34 PM
  4. Replies: 1
    Last Post: 01-07-2018, 11:33 PM
  5. Replies: 1
    Last Post: 01-07-2018, 07:56 PM
