1. Ned Squiggly's Avatar
    For the past couple of days my battery has been draining unusually fast with little to no use. I checked the battery stats and everything seemed normal except for cell standby- which was in the 30% range.
    I ran a health check and found that my screen has been staying awake- sometimes for up to 8 hours, even though the time out is set for 5 minutes.
    Could this be a virus?
    VZWsucks likes this.
    01-26-2018 09:19 AM
  2. Einsteindks's Avatar
    Nope. Potentially an app innocently running amok. The cell thing could be bad reception, and the radio working overtime trying to pull in a signal. Gsam battery has a 'sucker' feature to see who's draining the battery.
    01-26-2018 09:42 AM
  3. Golfdriver97's Avatar
    Pretty good first step. OP, have you tried a reboot?
    01-26-2018 09:57 AM
  4. Ned Squiggly's Avatar
    You mean turn of then back on?.. I have not. I'll try that now, thanks.
    01-26-2018 10:18 AM
  5. Golfdriver97's Avatar
    Yup. Turn off then on. It may just be an app that's stuck. Give it a full charge after the reboot and see if that makes a difference.
    Laura Knotek likes this.
    01-26-2018 02:14 PM
  1. Replies: 2
    Last Post: 01-28-2018, 12:00 PM
  2. Whay is battery draining on Galaxy S8.
    Last Post: 01-26-2018, 11:05 AM
  3. Replies: 4
    Last Post: 01-26-2018, 05:06 AM
  4. Why is my Battery icon showing an X
    Last Post: 01-25-2018, 07:05 PM
  5. Red X on Battery
    Last Post: 01-25-2018, 03:54 PM
