01-21-2020 03:45 PM
32 12
tools
  1. dablin's Avatar
    Or just download any player with an equilizer and set every frequency to min.
    Guido M likes this.
    02-20-2017 10:43 AM
  2. Nitsuji M's Avatar
    If you are rooted, this simple tweak to a text file solves this problem!!! Just add more volume steps than the default of 8.
    https://www.xda-developers.com/how-t...e-slider-root/
    09-05-2017 07:03 PM
  3. Some Body's Avatar
    Hi. I just bought the Ultra yesterday and uploaded all of my music. When I put my headphones on, I naturally put the volume on the lowest, just above mute. I never listen to music loud. I noticed that even in the lowest setting, it is too loud. It is almost like their version of low is loud. I have looked this up a bit online. Seems like this is an Android thing. Is there anyway to fix this? I tried numerous apps but no luck. I am in the process if contacting Motorola. Great phone just weird flaw.
    Any help would be appreciated. Thank you in advanced.
    This is a well-known problem with Android. It can be resolved by entering engineer mode and lowering the lowest "Media" audio level setting.
    Search for "engineer mode Android". There are also apps that might get you into engineer mode, depending on your phone specs.
    10-15-2017 10:12 AM
  4. siryk's Avatar
    Sounds like a defective unit. If the problem persists, return to a local store for a new one.
    Guys, i know that it is based on sound file quality, if you use very quality file or mp3 file, than there is problem with loudness. so convert this mp3 to worse quality and it is going.
    10-30-2017 12:18 PM
  5. Thomas Carter2's Avatar
    The only defective thing here is Android itself. As usual. Its programmers can mess as simple thing as volume control. Google has no shame giving such product to the enduser. And the problem still persists, so the bump doesn't matter.
    If rooting is the answer for anything, Android doesn't deserve to live.
    01-19-2020 06:14 PM
  6. Mike Dee's Avatar
    You are responding to a post from 2013.
    I have a Droid Ultra sitting in drawer somewhere. Its lowest volume was fine.
    01-19-2020 06:36 PM
  7. B. Diddy's Avatar
    Wrong, thanks for playing.
    Nikholas Pappas likes this.
    01-21-2020 03:45 PM
32 12
  1. Can I get the Cyanogenmod battery status bar icon on non CM ROM?
    By hometown blues in forum General Help and How To
    Last Post: 07-08-2015, 02:37 PM
  2. Activate New Off Contract MOTO X on Business Acct Line from Note 2
    By ejfiii in forum General Carrier Discussion
    Last Post: 12-10-2013, 01:35 PM
  3. How to slave ringtones on Nexus 5
    By AndroidDario in forum Google Nexus 5
    Last Post: 12-10-2013, 01:19 PM
  4. Screen Automatically Turning On/Off on power supply.
    By Michael Bialon in forum General Help and How To
    Last Post: 12-10-2013, 10:02 AM
  5. Doesn't sync on mobile
    By GabeW in forum Moto X
    Last Post: 12-10-2013, 09:34 AM
