1. AC Question's Avatar
    The phone is a Droid Ultra, 4G LTE SIM. This is a problem as the phone does not show the original option to switch from face forward to face away function of the camera. As I stated before, the flicking option doesn't work and the phone states that the camera is busy. Powering down doesn't work either and I'm unable to pull the battery. I was trying to avoid a total reset to factory. Any ideas?
    07-15-2015 07:06 AM
  2. lsmachado's Avatar
    You might want to register for a free Android Central account so that you can respond to any replies on your same thread instead of creating a new thread each time.
    Also, it is easier for anyone trying to help you to know which question you are referring to.
    Welcome to Android Central!
    Posted via the Android Central App on my Note 4
    07-15-2015 08:28 AM
  1. Replies: 1
    Last Post: 11-23-2015, 12:20 AM
  2. Replies: 34
    Last Post: 09-11-2015, 05:57 PM
  3. Replies: 3
    Last Post: 09-02-2015, 09:39 PM
  4. Replies: 0
    Last Post: 07-15-2015, 06:22 AM
  5. What Are The Best Microgaming Mobile Sites?
    By Shpak Olesia in forum Android Apps
    Last Post: 07-15-2015, 05:53 AM
