1. VoXiSo's Avatar
    This started last night, when I try to turn it on it shows the Motorola logo for a few seconds then vibrates and shuts down. When I go into the "Boot Selection Mode" and select Normal Powerup the phones boots to the Motorola logo vibrates and this time it just stays showing the logo it does not shut down or boot up just stays showing the logo... If I select recovery it shows the logo vibrates and shuts down, if I select factory it shows the logo vibrates and hangs on the logo screen. Any ideas? BTW... I did not run any updates before this started.
    Thanks.
    06-17-2016 11:26 PM
  2. VoXiSo's Avatar
    Incase anyone else has this problem I fixed it using the Verizon Motorola Software Update and Repair Tool
    B. Diddy likes this.
    06-18-2016 03:11 PM
  3. B. Diddy's Avatar
    Welcome to Android Central, and thanks for sharing your solution! I will move this to the Droid Ultra forum.
    06-19-2016 03:23 AM
  1. Replies: 4
    Last Post: 06-20-2016, 09:21 AM
  2. Moto 360 with magnet glued on it won't charge!
    Last Post: 06-19-2016, 11:12 AM
  3. Can the ZMax 2 be upgraded to marshmallow on AT&T?
    By mobster011 in forum Other ZTE Android Phones
    Last Post: 06-19-2016, 10:03 AM
  4. Replies: 2
    Last Post: 06-19-2016, 03:36 AM
  5. Replies: 1
    Last Post: 06-17-2016, 10:38 PM
