1. nrt757's Avatar
    I have responded late to countless text messages and emails due to this. Is there a simple solution I can use until motorola puts out a quality update?
    07-23-2011 09:10 PM
  2. El Jefe's Avatar
    SBF back to Froyo.
    07-24-2011 05:10 PM
  3. brianr8011's Avatar
    I've been away from the forums for a while, so this one is new to me. What exactly is the issue you are having with LED notifications?
    I had an issue last week where I wasn't getting ANY notifications from SMS (no led, no vibration, no icon in the status bar). It turns out than an SMS app that I had installed but wasn't using had been updated. Since I wasn't using it, I never opened it after the install was complete. Evidently the new version required you to basically set everything back up from scratch and since I hadn't set anything, it was over riding the settings I had in handcent and the phone itself. It took me forever to find this, and I had already uninstalled/reinstalled handcent, rebooted numerous times, and tried switching back to the stock messaging app before I figured it out.
    So, all that being said, do you have any apps that may be causing you to not be notified like you should be.?
    07-26-2011 05:51 AM
  4. Rocko's Avatar
    Handcent
    07-26-2011 02:54 PM
  5. sux2bu's Avatar
    Handcent
    Word, best text app out there. A MUST HAVE.
    07-26-2011 03:04 PM
