OK unboxed my X and i want to know if anyone else did this... before putting the battery in the phone, there is a tab that says pull. i figured it was like other electronics where you need to pull it off before it works. i pulled the damn thing and it ripped off . i then put my battery in and realized i wanted to change the SD card and i couldnt get the battery to come out. i went up to Verizon and i was told that the tab is to be pulled to get battery out.
Am i dumb or is it not clear? i ended up getting the battery out. it ripped off but it was still tacky so i just pressed it down and put battery back in.
With BB, I always had to do battery pulls but with this phone I guess i dont ever need to do this. so should i not worry about this then?
