1. scramblerider5's Avatar
    When chargeing the battery for the first time how do you know when it is fully charged when the battery is off?
    07-16-2010 11:45 AM
  2. scramblerider5's Avatar
    The screen is pluged in and the screen displays nothing is there a charge setting that stops chargeing when its full?
    07-16-2010 11:52 AM
  3. 1088933's Avatar
    Should just say "charged" on the lock screen or something
    07-16-2010 11:56 AM
  4. Cory Streater's Avatar
    The battery itself has circuitry that prevents over charging.
    07-16-2010 12:00 PM
  5. lsmunoz's Avatar
    But how do I know if the battery has fully charged?
    07-16-2010 01:59 PM
  6. zachflauaus's Avatar
    When you go to the lock screen, it will say "Charged." Otherwise it will display the charge it currently has.
    Sent from my DROIDX using Tapatalk
    07-16-2010 02:23 PM
