prenoobster
How did you turn off the sound on the swype keyboard? Thanks!
under settings->keyboard->swype settings
not sure if any of you have come across this yet, but when your phone is ringing, you can flip the phone to face down and it will swap it to vibrate (great for if you are in a meeting and forgot to silence your phone)
Don't add your facebook or your contacts will auto sync with your friends. Instead download facebook and use syncmypix just to synch the photos. Also get sms-pop up
You can edit Beautiful Widgets Home without deleting/recreating it.
Just tap on the weather portion to go into the extended forecast, then click the Settings button and you can change the skin and/or configuration from there.
1. Open the music app
2. Play a song
3. Put the phone to sleep
4. Press the power or home button to wake it and you should see a music widget to reverse, skip, or pause songs without unlocking the device
Swype cursor control and edit keyboard is accessed by dragging the Swype key to the Sym key. Much better editing function!
Oh dear god. Best. Tip. Ever. (Minus the battery tab tip for the few it saved from having their warrenty voided)
I don't know anything about the battery tab tip, but I second your nomination of the swype edit tip being the best ever.
