KQCrackberry
please be more specific...
Um my options in Location and Security are as follows:
e911 only
use wireless networks
use gps satellites
enable assisted gps
calibrate compass
change screen lock
use visible pattern
use tactile feedback
security lock timer
set up restriction lock
visible passwords
select device administrators
install from sd card
set password
clear storage
where in here can you disable the slide lock while leaving the pattern enabled? entering the "change screen lock" menu simply alters the pattern/pin/pass but the slide is enabled by default. as far as i can see the slide lock can't be disabled
found out that you can actually disable the lock screen in the settings menu:
menu>settings>location & security and from there just uncheck the screen lock option. best part is that you can disable the swipe lock, while still keeping a passcode or pattern lock if you want
e911 only
use gps satellites
enable assisted gps
calibrate compass
change screen lock
use visible pattern
security lock timer
visible passwords
set password
clear storage
