1. Matt Kline's Avatar
    I can't hardly hear the phone ring when its in my pocket. Is there an app or a hack to somehow change the phones settings. I was reading on crackberry that they could get into the software and make it louder. Or do we need to root the x for this to happen?
    07-19-2010 08:23 PM
  2. 1088933's Avatar
    Needed root for the Droid for the louder volume but I'll check some apps for this that don't require root
    Sent from DROIDX using Tapatalk
    Matt Kline and RoYaLe42 like this.
    07-19-2010 08:47 PM
  3. largeselection's Avatar
    I (and many others from the looks of similar threads) would also be interested in a fix for this. Thanks for your research.
    07-19-2010 09:07 PM
  4. Matt Kline's Avatar
    Thanks for checking it out. I'm new to Android and there wasn't anything in the market.
    It wouldn't be the end of the world but sometimes the job sites get pretty loud.
    07-19-2010 09:19 PM
  5. 1088933's Avatar
    Its just for root users sadly
    Haven't found anything for louder volume that doesn't need root which makes sense, you're gonna have to have superuser to be able to go beyond what they have volume programmed for. Sorry folks. But it won't stop me from trying to get root on this bad boy! . Louder volume is always a plus
    07-19-2010 09:34 PM
  6. largeselection's Avatar
    Well I'm sure we will get a fix (with root if necessary) soon.
    07-19-2010 09:41 PM
  7. rjdangerous's Avatar
    I downloaded a' loud' ringtone and that was louder and made a difference
    07-19-2010 09:42 PM
  8. jasjeetsingh's Avatar
    what are you guys talking about here that can fix volume with rooted user?
    09-22-2010 09:06 AM
