And I will get us started. Here is what my X looks like from left to right:
BatteryLife on AppBrain, I use it too and it's looks real slick and does it's job.
Dude, why do you have Natalie Holloway in your quick contacts?
what dock are u using? is that a theme?
terpitude, what battery indicator are u using in the notification bar?
thanks terpitude for the info, i'll check out that battery indicator. i looked in my launcher pro plus for worded icons, but dont see the option...hmmm
These http://db.tt/JmUYNS
Thats the link to the icons and its about 100+ different ones to choose from. You also need to download the dock to go with it because those are transparent.
very nice, thanks. i assume they would work with any dark background as well, yeah?
nice, thank you....so, i'm an android noob. i assume you just download the files to SD card, and apply in the custom settings in LP Plus?
Big thanks for these. They look sick! Where did you get them so I can look for other icons? I'm always tweaking mine but these will probably stay for a while.
Is there a way to make the clock font from the lock/unlock screen appear on one of the home screens?
