Does anyone elses phone keep switching silent mode on by itself? It's been doing this to me for the past couple of days, causing me to miss calls and emails.
If you've installed a Silent Mode/Vibrate Mode/Ringer Mode toggle widget be sure you arent accidentally grazing it and unknowingly putting the phone into silent/vibrate modes. This happened to me before, I just moved the widget to a lesser-used screen.
My wifes phone was doing the same. I called support and they had me turn it off and pull the battery and hold the power button down for 30 seconds. Then put battery back in and power on. So far it has not done it again But its only been a week...so time will tell if its a long term fix or not.
