1. rjdangerous's Avatar
    I have an issue when setting multiple alarms, say there is a 5 minute difference the first one sounds but the second just vibrates. Other people having this?
    Try setting 2 for a minute apart and dismiss the first and see if the second sounds
    09-16-2010 06:48 AM
  2. rooktdphi's Avatar
    Our just get up when the first alarm goes off you lazy mofo
    09-16-2010 06:55 AM
  3. rjdangerous's Avatar
    i wish.. just went to first shift and 4:30 is too early
    09-16-2010 05:11 PM
  4. rooktdphi's Avatar
    Could be your task killer that is causing the problem, read in another topic it was causing their alarm to vibrate
    09-17-2010 07:06 AM
  5. hossberry's Avatar
    my complaint is it's just not loud enough and I'll just sleep right threw it
    09-17-2010 07:13 AM
  6. rjdangerous's Avatar
    No task killer homie, plus the first works.
    09-17-2010 07:33 AM
