C Camphill Active member Jul 19, 2010 27 0 0 Visit site Sep 27, 2010 #1 Anyone know how to disable the Home button double-tap? I know you can install Launcher Pro but I do not want to. I only want to disable it...or change it to an app that's not one of the few defaults.
lterry913 Well-known member Sep 20, 2010 443 2 18 Visit site Sep 27, 2010 #2 settings>applications>double tap home options at bottom...I don't know if there is a do nothing option.good luck
