1. sleonard's Avatar
    I have a 2011 Ford Edge with MyTouch and Sync. the system works great except when i try to stream music using my Droid X bluetooth. I lose the connection. i have never had this work. I have disconnected wifi and still no luck. Thoughts?
    09-28-2010 11:42 AM
  2. wildman's Avatar
    I think that the Droid X bluetooth streaming feature does not play well with all units, I can not stream with my Droid X but I tried my Imagio and streamed without issues, I do not know if its Android or Droid X hardware that causes this issue.
    09-28-2010 12:01 PM
  3. sleonard's Avatar
    Thanks for the try.
    09-28-2010 04:31 PM
  4. gassnerja's Avatar
    Verizon sent out an update in August that broke BT play back on Sync. Check to see if you have 4.5.602. Still trying to figure out a work around other than using the line in or usb.
    09-05-2011 07:32 PM
