09-22-2017 05:17 PM
27 12
tools
  1. cheryl montgomery's Avatar
    I changed on the voice recorder app to off. Haven't been on phone since. A tip from google when i asked for help (?)
    p.s. Last discussion should have been if anyone would be able to help me.
    09-22-2017 03:45 PM
  2. B. Diddy's Avatar
    I was asking if you had read through this thread first, before posting your question, since there are other proposed solutions (including checking to see if you have a "minute minder" option turned on). Can you confirm that you've checked the possible solutions mentioned here and that they don't help? If so, can you give more details about the beeping? How frequent is it -- every few seconds, or about every minute? Is it a simple beep, or is it a distinct group of tones? Does the other person on the line hear it, or only you?
    09-22-2017 05:17 PM
27 12
