1. rog152's Avatar
    Since the 2.2 update my motoblur clock widget is not working and i also believe my weather widget is not either. The weather widget is always about 10 degrees lower that other weather apps or widgets like weatherbug.
    Now if I refresh the motoblur weather widget the clock widget will change to the correct time but after that it does not keep time.
    Have this been discussed here in other post?
    Can someone help me with this?
    I thought it was Launcher pro plus so I deleted it but that did not fix the problem.
    10-15-2010 12:58 AM
  2. Bond32's Avatar
    Delete them and readd them.
    10-15-2010 12:56 PM
  3. Arelunde's Avatar
    Launcher Pro Plus will interfere with Moto widgets. If you want to use LP+ as launcher, you will need to use LP widgets or download individual widget apps. At least so far, Moto widgets just don't seem to be compatible.
    10-15-2010 01:09 PM
  4. DroidDev's Avatar
    My moto widgets work just fine with LP+
    10-15-2010 03:11 PM
  5. Arelunde's Avatar
    Interesting! I'll have to try again. Maybe there's been an update to LP+. Been problematic for me so far. Glad to hear it can work!
    10-15-2010 03:24 PM
