1. Bob61's Avatar
    New to Droid, looking for recommendation of in car bluetooth speaker phones that work with the Droid X. I had looked at the Motorola T-325 but read that it has problem working with Droid X. Anyone using one that they would recommend?
    11-30-2010 03:02 PM
  2. wildman's Avatar
    I am using Jabra Cruiser In-Car Bluetooth Speakerphone that does very well..
    Set Your Location
    11-30-2010 04:33 PM
  3. Bob61's Avatar
    From the responses it looks like selection is somewhat limited for use with Droid X. Thanks for the response.
    12-02-2010 08:09 AM
  4. wildman's Avatar
    Any hand-free speaker phone unit should work, the Droid X bluetooth support all profiles to be used with hand-free devices, some car unit appears to be the issue because most radios do not support a2dp profile that the Droid X can use for streaming bur phone feature usually works fine.
    12-02-2010 11:27 AM
  5. Dfresh's Avatar
    I cosign with wildman jabra crusier is probably the best one. On the droid x it supports google navigation which was very important to me.
    Sent from my DROIDX using Tapatalk
    12-03-2010 12:58 AM
  6. Bob61's Avatar
    From my reading of reviews of various units I've noted that some units, such as the Motorola T325 has problem with Droid X in that it won't download the contact info. Strange, you'd think Motorola devices would work with Motorola Droid X
    12-03-2010 07:19 AM
