1. Lonman06's Avatar
    I am experiencing a very annoying problem and I'm not quite sure what to do. For someone reason my phone will no longer save pictures to my sd card. When I take a picture with the camera it makes the sound and then the camera app will just close. I also cannot play any of the music on my sdcard. It says file type not supported, but these same files used to work. I have formatted the card and still nothing is working.
    Please help!
    12-11-2010 10:51 AM
  2. Johnly's Avatar
    could be the sd card? Manufactures include generics. Dunno though.
    12-11-2010 11:05 AM
  3. Lonman06's Avatar
    My computer picks everything from the card just fine though?
    12-11-2010 11:06 AM
  4. p08757's Avatar
    Make a backup of your card to the computer. Format the card from the system menu on your X. Restore from your PC. Enjoy.
    12-11-2010 11:17 AM
  5. Lonman06's Avatar
    It won't let me format from the phone...
    I hit unmount and it just sits there an says unmounting. Left it for about 10 minutes and the format option was still grayed out.
    12-11-2010 11:24 AM
  6. digitalslacker's Avatar
    if you have an adapter micro > full SD put it in your computer
    you could also try to plug the phone into your comptuer, switch to USB Mass storage mode and then format the card from Windows Explorer by right clicking and hitting format.
    hope that helps.
    12-11-2010 06:29 PM
  7. Lonman06's Avatar
    hope that helps.
    I ended up having to restore back to a previous bootstrap backup. Then everything worked, not sure what have caused the problem. Perhaps a corrupted file?
    12-11-2010 06:53 PM
