1. Rob3rd's Avatar
    Cant locate for 30.03 can anyone help? Thankx
    12-14-2010 06:34 PM
  2. greydarrah's Avatar
    I think this is what you're looking for:
    Droid X: 2.3.32 Full SBF
    Rob3rd likes this.
    12-14-2010 08:27 PM
  3. digitalslacker's Avatar
    that's the link for .320, .340 is the latest OTA version so i'll caution you by saying that you may want to go a step further and follow TBH's process to get you to .340 from .320.
    the issue is that it's POSSIBLE that if you are on .320 and you take the next OTA update from vzw/moto that you'll have an issue because the kernel versions are different.
    Most agree the kernels are operationally the same...but the version number between .320 and .340 is not the same.
    Some believe that could cause issues.
    TBH Patches: 2.3.340-System, Baseband, 2.3.340-Kernel, Bootloader
    Edit: to clarify, .320 was a leaked version of the .340 official update that came out a few weeks before the OTA.
    Rob3rd likes this.
    12-15-2010 08:30 AM
