1. dubge's Avatar
    I am running apex 1.4.1 and it has been running flawlessly until now, I put the phone in airplane mode and tried to connect to wifi from there, I wanted to test it out for upcoming plane trip and out of the country use on wifi, I could not get it to connect to my network, it would sit at obtaining ip address and every once and while it would flash disconnected then back to obtaining ip address, so I gave up and turned off airplane mode.
    Now I can not get my phone to connect to my network! I have rebooted, removed the battery, even forgot the network and reset it up and I am still getting the obtaining ip and disconnected.
    Any clue what to do?
    03-06-2011 02:19 PM
  2. Jashley73's Avatar
    I too have been having problems. My phone is bone stock and has the worst WIFI i've ever seen. It barely connects to my home network (just one small room away,) says that signal strength is "poor," and drains the battery with WIFI turned on. I came from a BB Bold, and this was never a problem before...
    03-06-2011 03:41 PM
  3. .46caliber's Avatar
    Find the forum that the Apex developer/s frequent most and seek help there. I'd imagine they're on either DroidForums.net or XDA.
    03-06-2011 05:45 PM
  4. dubge's Avatar
    Thanks, I rebooted my router and all is fine now.
    03-07-2011 09:54 AM
