1. FrankWhite77's Avatar
    Trying to go to stock on my droid x so I can do a restore of a backup and I am on a mac. I NEED this restore before work tomorrow or else I'm sunk
    03-28-2011 10:27 PM
  2. Smitty_82's Avatar
    Try this link http://www.droidxforums.com/forum/dr...pdate-zip.html you are able to flash this in recovery.
    03-28-2011 10:48 PM
  3. FrankWhite77's Avatar
    Let me get this right before I do it:
    I hold home and power and go into recovery even though i'm on non rooted gingerbread
    then I choose the file which will be under?
    Then I am on stock and can root/bootstrap and restore my backup which i hope has my contactS?
    03-28-2011 11:03 PM
  4. FrankWhite77's Avatar
    Signature verification failed
    Updated aborted
    03-28-2011 11:12 PM
  5. Smitty_82's Avatar
    Didn't know you were on gb. You will have to do the sbf with your computer, this was only for froyo. Sorry for the confusion.
    03-29-2011 01:00 AM
