Jeremy
Original Member
If anyone wants a nice pouch case that is promised not to scratch your phone you can always use a sunglass pouch. You can get them at any Sunglass Hut. It works...
I've been looking high and low for alternatives to VZW's case. Almost all cases use a magnet to secure the flap; very few use Velcro.
I did find Nite Ize' medium sized side case that should fit my Droid at Bass Pro Shops online. Haven't checked the nearby store yet. It's a dark brown leather and looks to be a bit nicer looking than the usual black leather suspects.
Nite Ize Genuine Oil Skin Leather Clip Case Sideways
If you want a solid holster case with Velcro check out Marware's C.E.O case for the iPhone 3GS. Fits perfectly on the droid.
Thanks for the tip. Found it for under $25 on Amazon.
So I'm guessing most Leather Iphone pouches would work?
Went into BB and almost bought one last night but wasnt sure. I want one with a suade interior to keep the phone unscratched.
I would assume so. I have a bunch more at home that I will double check for you. That Marware one I listed above does indeed have the soft suade interior.
Anyone here sporting any of the ebay Hard Rubberized Plastic Cases?
Can't really post links or pics yet... got to build up a bigger post count.
Here's the link though:
For Motorola Droid Hard Rubberized Plastic Case Black - eBay (item 150389459275 end time Dec-16-09 00:09:48 PST)
I just got mine and cant get the front piece to stay/snap on, but otherwise it looks fairly nice.. lol
That's a nice selection.Found some cases that look promising, fommy.com, has anyone else order one of these and had any luck and comment good/bad or otherwise. Here is the link to the site:
Motorola Droid A855 Cases Store - Fommy.com
