1. pappy53's Avatar
    Which uses more battery_ wi-fi or 3G ?
    04-30-2010 03:04 PM
  2. Roy Aguilera's Avatar
    I think they use the same amount. Not sure though.
    04-30-2010 03:46 PM
  3. Cory Streater's Avatar
    On the Motorola Droid, Wi-Fi definitely used less juice. I'm not sure about the Incredible yet. It seems like both WiFi and Cellular drain the battery equally as fast from what I can tell.
    04-30-2010 03:57 PM
  4. takeshi's Avatar
    3G on the Droid.
    04-30-2010 07:16 PM
