I have been to about 15 different states in the past two weeks and I get static on every call. It is most noticeable when the phone is ringing, in-call right before and after the caller speaks, and occasionally when we are speaking. Sound on this phone can be very warbly and clippy. It is really getting annoying.
I have done a soft-reset, battery pull, speaker phone reset, turned off voice privacy, and tried all three vocoders in the programming menu. I still get static and garbly warbly audio. That's the best way to describe it.
Does Verizon give you a refurb when you exchange or a new phone? Everything works good on my phone, but the faint static and overall voice quality is not acceptable. Does anyone else notice how warbly and clippy the audio quality is? It was the same on the demo Droid at the Verizon store; however, there seems to be many of you without these problems.
Someone mentioned that Verizon was going to fix these issues in an upcoming update, but if only some people have this issue then I think it may be a hardware defect?
