1. vjr021's Avatar
    What would cause a GSM Milestone to stop working on a network?
    Can you re-install the software somehow??? It seems to be some sort of software issue..
    06-02-2010 06:33 PM
  2. vjr021's Avatar
    06-02-2010 06:38 PM
  3. Brett's Avatar
    is this rooted? i dont remember if the Milestone has root yet but if you are i would wipe through recovery and reboot. if you're not rooted then i would reboot and see what happens. if that doesn't work, try to put it into airplane mode and then turn airplane mode off. hope that helps man
    06-02-2010 09:51 PM
  4. vjr021's Avatar
    I know it is not in airplane mode, that would cause the signal level meter to show a small airplane, this is showing just an "X"..
    Not rooted, any other ideas?
    06-03-2010 06:04 AM
