1. callmebob's Avatar
    Is anyone else having problems with the POP email client on the Droid. Mine seems to get stuck loading and I have to kill it with ATK. Once that happens I can get the email to come down again.
    Also, why does it continue to download the same email 2,3,4,5 times? I have received the same email over and over no matter if I delete it from the phone or leave it in my inbox. Anyone?
    11-09-2009 04:29 PM
  2. iler19's Avatar
    Hey i am having the same issues with my emaili too. All the emails had a red tag next to them and it was hard to distinguish which one were read and not. mine kept downloading too. i had mine set to check email every 15 mins i was getting so annoyed with it so i deleted the account. i dont know what is wrong with it, just wanted to let you know that you are not the only one out there.
    11-10-2009 05:40 PM
  3. darkstar's Avatar
    i just set up my gmail to download my pop email..
    11-10-2009 05:51 PM
  4. matrix2004's Avatar
    How???????
    11-10-2009 09:51 PM
  5. krafticus's Avatar
    I am having the same issue where certain emails keep coming in, and can't seem to stop them. A tad annoying to say the least. Looking for a nice fix
    11-18-2009 09:23 AM
  6. darkstar's Avatar
    go into Gmail and look under settings > Accounts and Import > Check mail using POP3
    I'm not sure how frequently it checks your mail... but i know its not immediate.
    11-18-2009 09:34 AM
