1. GenericMessage's Avatar
    Anyone notice that?
    My flash is going off way too soon and all my pictures using the flash are now useless
    06-09-2010 10:47 PM
  2. asdr24's Avatar
    Anyone notice that?
    I hardly ever use mine for pics but after seeing this I snapped 5 quick shots and all of them had a good flash. 1 of the 5 seemed a little darker than the others but I could be wrong.
    Are you on Froyo? If so you can use the exposure options (last one on the right of the new options) to make them a little lighter which could help. Hope this helps.
    06-09-2010 10:51 PM
  3. GenericMessage's Avatar
    No, I am stock
    06-09-2010 10:52 PM
  4. takeshi's Avatar
    Generally my issue with the flash is that it washes out everything.
    06-10-2010 09:46 AM
