1. dvader's Avatar
    Has anybody else noticed that when using the GPS/Sat. the phone gets very hot.
    for example if i'm messing around any GPS apps and the little satellite symbol is lit up, my phone gets really warm./hot
    if I'm not using that, it's room temp/cool.
    edit : sorry this should be in the motorola droid X forum. pls move
    07-21-2010 03:21 PM
  2. terpitude71's Avatar
    its actually probably fine here. its a pretty common occurrence on most android phones
    07-21-2010 06:01 PM
  3. corydunbar's Avatar
    it isn't anything you did. GPS is a very hardware heavy function for an android device and you phone isn't 100% efficient so it produces heat. But since GPS is so demanding, it produces a lot more heat. all the while more heat makes the hardware even less efficient. so in general battery life just stinks when using GPS.
    07-21-2010 09:19 PM
  4. GenericMessage's Avatar
    Try charging your phone while getting GPS directions while streaming Pandora to your cars stereo!
    Then you'll know what heat is
    07-21-2010 09:20 PM
  5. takeshi's Avatar
    Yup.
    07-22-2010 09:20 AM
  6. Zorro1's Avatar
    It's the screen while you're running all of it. I turn it off while driving until I want to check something, and it cools right down.
    07-22-2010 09:50 AM
  7. mrwashy#AC's Avatar
    I've done this, and yeah it gets incredibly hot. But it was chugging along nicely until I got a text message and froze up.
    07-23-2010 09:21 AM
