1. dancingcrab's Avatar
    Okay, I followed Droid-Life's guide for updating to Froyo. I did everything as it said, I did the same thing for 2.1. Now my Droid won't get beyond the white circle with the Motorola 'M' in it.
    First, I left it for twenty minutes... nothing.
    Then I pulled the battery, same problem.
    I've even booted into recovery and attempted to update again, but it fails.
    What should I do?
    Manual Android 2.2 Update for Motorola DROID | Droid Life: A Droid Community Blog
    08-03-2010 05:08 PM
  2. Melon Bread's Avatar
    Well it seems it did not flash correctly.
    After looking at the post:
    I would say just try it again, or flash back to 2.1 (I imagine Google will have links for you)
    08-03-2010 05:10 PM
  3. dancingcrab's Avatar
    Thanks for the reply. I've already tried it again, as I mentioned. Will try to find a 2.1 update.zip.
    08-03-2010 05:18 PM
  4. brandonx1000's Avatar
    08-03-2010 05:25 PM
  5. Menno's Avatar
    you weren't rooted were you?
    08-03-2010 05:57 PM
  6. dancingcrab's Avatar
    Nope.
    08-03-2010 06:10 PM
  7. Menno's Avatar
    hmm.. I just ran it on my dads, it stuck at the droid eve for about 2 minutes, but it's flawless now.. trying to get the phone back from him to run linpack
    08-03-2010 06:11 PM
  8. xliderider's Avatar
    Yep, use RSD Lite to flash back to 2.01, then download the zip file to update to 2.1 again.
    08-03-2010 06:20 PM
