installed the official 2.2 froyo update and decided i would reset my phone and reformat the sd card.
only problem is when i go to the android market it automatically redownloads all the apps i last had installed, but they are all stuck at 0%. none of them are making any progress. called *611 and verizon support is useless.
i've already rebooted my phone, took battery and sd card out and put back in. same problem even after several reboots. nothing will download from the marketplace but i still get internet usage out of the phone and able to make calls surf the interwebs.
