12-08-2009 03:59 PM
37 12
tools
  1. McNooberson's Avatar
    Like the iPhone ya know? I have a lot of Apps and it would be cool if I could see them in home screens rather than the pulldown menu. Is there an application for that maybe?
    11-19-2009 07:15 PM
  2. thekC's Avatar
    There's apps in the Market that you can DL to make that happen.
    Open Home (paid and lite versions) is one of them.
    11-19-2009 07:45 PM
  3. Roy Aguilera's Avatar
    OpenHome, PandaHome and dxTop are a few.
    11-19-2009 07:56 PM
  4. largeselection's Avatar
    DxTop is great.
    11-19-2009 08:17 PM
  5. leathernuts#WP's Avatar
    I downloaded GDE and have up to 6 home screens
    11-19-2009 08:26 PM
  6. Roy Aguilera's Avatar
    DXTop as an update.
    11-19-2009 08:31 PM
  7. mclarryjr's Avatar
    Are you guys getting any lag using them?
    11-19-2009 08:54 PM
  8. largeselection's Avatar
    No lag that I've noticed with DxTop. However, I'm not using any theme. Basically just using the stock theme but with the added functionality of dxtop (the 4 panes, swipes to get to the panes, customizable app drawer, etc)
    11-19-2009 09:08 PM
  9. keepsakenw's Avatar
    I have both Open Home and dxtop loaded. I kind of like Open Home just a bit more because it has seven screens available and just a more natural movement to it. Left and Right movement. dxTop is a good product which has four screens available but works in a box motion. So right once then up once then left then down. I always get confused which one I'm on. But dxTop has drawers so it's a toss up.
    Play with both then return the one you don't like. That's what is great about the app store.
    Another one coming out but not ready for prime time yet is Sweeter Home. Take a look at it and it will blow you away. I downloaded it but it is not ready yet. Still lots of bugs.
    11-19-2009 09:20 PM
  10. keepsakenw's Avatar
    And to answer Mclarryjr there is not lag that I have noticed including when I switch between home screens. Very fast.
    11-19-2009 09:21 PM
  11. ScottsdaleHokie#AC's Avatar
    Panda only has the stock 3 right now. More are coming from what I hear.
    11-19-2009 09:31 PM
  12. smacinskyjr's Avatar
    GDE has a total possible of 7 screens. I have tried several home alternatives, and GDE is by far the best!!! it is exactly what i was looking for. Plus it has really cool features.
    11-19-2009 10:45 PM
  13. droidweasel's Avatar
    are there like free themes? ive been looking and everything costs money....are there any free themes out there?
    11-19-2009 11:54 PM
  14. Roy Aguilera's Avatar
    There is free themes.
    11-20-2009 12:00 AM
  15. droidweasel's Avatar
    really? where? and dont i need to pay for some home thing first'?
    11-20-2009 12:06 AM
  16. Mr.Miagi's Avatar
    Panda for Droid has MORE then 3 screens, you can create as many as u like by just dragging a widget or icon to the left or right and the screen will be created. I CURRENTLY have 5 and can add a sixth.
    Panda for the Droid is free in the android market, just search panda home. It is quick and no lag. The only bug I have seen is sometimes when long pressing an icon it brings you back to the home screen. This is very very tolerable and should be resolved soon since its a work in progress. It only happens a couple times a day.
    11-20-2009 12:24 AM
  17. bwhite757's Avatar
    I have GDE homescreen on my Droid. Up to 7 different homescreens, different transitions, zero lag, just awesome. I love it on my Droid.
    11-20-2009 02:18 AM
  18. peterr22's Avatar
    gde is awesome
    11-20-2009 09:38 AM
  19. TheProfessor's Avatar
    I just downloaded Sweeter Home and it is AWESOME! It has amazing potential and so far...no problems.
    11-20-2009 10:25 AM
  20. Roy Aguilera's Avatar
    You can download Panda Home, its free also and use the free themes that are out there.
    11-20-2009 11:10 AM
  21. TreyDaPrince's Avatar
    Correct me if I'm wrong but the only one that officially says its compatible with the Droid is Panda Home correct?
    11-20-2009 02:04 PM
  22. Roy Aguilera's Avatar
    Nope. So is dxTop
    11-20-2009 02:09 PM
  23. darkstar's Avatar
    I like dxTop.. it has 4 home screens..
    11-20-2009 02:21 PM
  24. teknomedic's Avatar
    so... can anyone tell me why they feel the need to limit how many screens we can have????
    11-20-2009 02:33 PM
  25. Roy Aguilera's Avatar
    No idea why it s set up that way. But 3 is better than the 1 I had on the Storm. With the S1 the most screens I got was 3 with Appleberry Pano. With certain home replacement apps you can have up to 7 screens.
    11-20-2009 03:07 PM
37 12
