1. csiguy1's Avatar
    What the heck happened, my battery went dead after 3 hours in the case. I usually get 16 hours. I had it in the case on my hip and went to look at a email and the battery was in the red after only about 3 hours. I usually get 16 hours with normal use. I have had the phone since Nov 6 and this never happened in the past. Was there some sort of update or something that made the battery drain so quickly?
    11-28-2009 12:45 PM
  2. mclarryjr's Avatar
    No updates were sent. What kind of case were you using? If it had a magnet it might of stayed on in car or bedside mode which would drain your battery.
    11-28-2009 12:51 PM
  3. csiguy1's Avatar
    The case is the plastic one from VZ for $29.00 this has never happened before. The case is all plastic, no magnets.
    11-28-2009 01:19 PM
  4. Jeremy's Avatar
    Something was running to cause your battery to drain like that. I'd fully charge it and see what happens. You really don't have any other choices. If it does it again you may want to perform a hard reset.
    11-28-2009 01:30 PM
  5. csiguy1's Avatar
    Thanks Jeremy, I think that fixed it. Must have had a brain fart.
    11-28-2009 02:35 PM
  6. Jeremy's Avatar
    Hope things work out for you.
    11-28-2009 02:39 PM
  7. ChocoBilly's Avatar
    So what does a HARD RESET does in this case to solve the problem?
    11-28-2009 03:47 PM
