1. Theodore55's Avatar
    Everything is working but the weather. It says F for farenheit but no city or temperature. It found my city when I first put it on the charger, but it won't show any info. Thanks for any help.
    12-03-2009 09:24 AM
  2. keepsakenw's Avatar
    I have noticed the same issue. I thought it was just too cold for it to show...in the mid teens right now. Not sure what the problem is.
    12-03-2009 10:02 AM
  3. clackout's Avatar
    Mine was working for like three hours then started doing the same thing
    12-03-2009 01:25 PM
  4. Adiliyo's Avatar
    mine was working last night (the last time i looked at it)
    but i think i remember it not showing temps closer to when i bought it.
    i think it has to do with it just not getting valid data from wherever it pulls the info from
    12-03-2009 01:33 PM
  5. SLEEP3R's Avatar
    mine started to do the exact same thing as of 3 or 4 days ago. I have set location manually , had it automatically find it , unchecked the show weather and so on .
    sometimes it works and now most the time it dosnt . just like others it has location but just shows F and no info.
    so it seems more than a few of us are experiencing this problem . and BTW it worked just fine out of the box .
    12-03-2009 03:16 PM
  6. BigTex71's Avatar
    I have noticed this also. To get mine to show it again I have to power off the phone and then power it back on.
    12-04-2009 09:29 AM
  7. mclarryjr's Avatar
    Mine usually works when I go to bed then when I wake up it off.
    12-04-2009 10:15 AM
  8. graymulligan's Avatar
    Mine's hit or miss...sometimes its there, sometimes it's not. Weird.
    12-04-2009 01:48 PM
  9. barkingburro's Avatar
    Same here, hit or miss. Was stable up until a day or so ago.
    12-05-2009 02:02 PM
  10. khessjr's Avatar
    If I power the Droid off, then back on, then place on the dock, the weather shows. If you remove the Droid from the dock to use, then place back on the dock the weather info is gone until you power the phone off and back on again.
    12-14-2009 11:37 AM
