1. white_star_32's Avatar
    ok i hope someone can help me with this, i made a manual change to the voice settings. i can't for the life of me remember what it was called and how to do it. for lack of a better term i'm going to call it a 'codec'.
    apparently the droid uses 'codec 1234', but there is also an option to change to 'codec 1234 beta'. (i didn't notice any difference really) you had to enter a sequence on the dial pad (it was something along the lines of 'program') and then you could login in to a debugger program.
    anyone else done this or heard of it?
    12-09-2009 07:29 AM
  2. tdawgui's Avatar
    ##PROGRAM (then hit send)
    "Enter SPC password" pops up ==> type "000000" then hit verify
    Select "04 Vocode"
    You probably selected EVRC-B ==> the factory default is EVRC.
    12-09-2009 10:13 AM
  3. white_star_32's Avatar
    that's it - thank you much!!
    i followed the instructions from a different website, do you know the site?
    12-09-2009 10:19 AM
  4. Adiliyo's Avatar
    the instructions are in the sticky here i think.
    originally i think it was posted up in howardforums
    12-09-2009 10:56 AM
  5. Jeremy's Avatar
    Here is the link from the sticky thread: http://forum.androidcentral.com/moto....html#post9679
    12-09-2009 11:25 AM
