1. gringolindo2u's Avatar
    I'm trying to login to a website to view home surveillance. It will not show the content of the website, when I do it from a computer I have to click on the WebRecClient Activex Control Module at the top of the page. Can the Droid do this? Could not find a thread on this subject. Thanks
    12-09-2009 12:28 PM
  2. ircactus's Avatar
    I'd have to say no activex for android.
    12-09-2009 02:25 PM
  3. Flyguide83's Avatar
    I think you will need flash player 10 to do this... Its well on its way now that the Droid has been Rooted...
    12-09-2009 02:26 PM
  4. ircactus's Avatar
    Flash has nothing to do with activex controls. I don't believe activex works on winmo either. Some security cams like axis also have java to enable you to vew them rather than the imbedded activex control. If this is not the case, i don't believe you'll be doing it from your phone.
    12-09-2009 03:06 PM
  5. Flyguide83's Avatar
    I was thinking more along the lines of, now that droid is rooted, maybe they can finger out how to make it work.
    12-09-2009 03:47 PM
  6. ircactus's Avatar
    unless the control was compiled for specifically for it i doubt it. ActiveX is Microsoft proprietary. But I'm done being negative about it. Eitherway. Enjoy.
    12-09-2009 04:58 PM
  7. gringolindo2u's Avatar
    It looks like it might be specific to that site. "WebRecClient Active X control Module" is what I click on when loading the page on the computer. I was hoping there was a setting that I missed that would allow this. Oh well! Thanks for the help.
    12-09-2009 05:19 PM
