1. AC Question's Avatar
    I use my Droid phone to schedule meetings when out of office. It sounds like the only thing I can do is use phone calendar and not desktop calendar to avoid missed appointments or overbooking. Is that right?
    04-28-2015 08:43 PM
  2. B. Diddy's Avatar
    Are you following up on another post you made? Please consider registering on Android Central so that you can continue the discussion in the thread you originally posted. It's confusing if we can't reference the prior post you're talking about.
    Regarding your question, the best thing to do is to use your Calendar app and make sure that the event you enter is associated with a calendar from your Google account, not the Phone/Device account. You can select which account it's associated with when you're entering details of the event. If it's with the Google account, then the event will automatically sync to your Google Calendar in the cloud, and it will appear on the desktop immediately (i.e., if you're looking at Google Calendar in your computer browser).
    04-28-2015 11:58 PM
  1. Unrooted the device, Now I can't re-root.. What to do?
    By Aserar in forum Android 4.4 KitKat
    Last Post: 11-28-2015, 08:50 PM
  2. Turbo will not accept new password for Kindle
    By MikeLip in forum Motorola Droid Turbo
    Last Post: 04-29-2015, 07:23 PM
  3. From Sprint to T-Mobile
    By tourbound129 in forum T-Mobile
    Last Post: 04-29-2015, 05:25 PM
  4. What happened to Trusted Faces?
    By verendus in forum Samsung Galaxy Note 4
    Last Post: 04-29-2015, 08:07 AM
  5. Samsung gs3 - how to delete photos
    By perplexec in forum Samsung Galaxy Nexus Rooting, ROMs, & Hacks
    Last Post: 04-29-2015, 12:54 AM
